Here's a couple of views of the stacked sections; mimicking the assembled cut foam pieces.
![](http://img.photobucket.com/albums/v724/NeilBlanchard/CarBEN%20EV%20Concept/th_CarBEN-NewModel.png)
Please note that the door, wheel skirts, and the hood are separated from the main chassis, just as the foam will be, so they can be assembled separately.
I plan on importing this into SketchUp and smoothing it -- this will make the model much smoother and "tighter" so that hopefully I can then do CFD testing; which should give an approximate Cd (coefficient of drag).
