Old 05-11-2012, 02:37 PM   #5 (permalink)
Soichiro
Elise - '13 Hyundai Elantra GLS
Welcome to the site Porxster. First, if your goal is MPG (which I assume it is since you are on this site), I would actually recommend against adding a RAM intake. The results here don't look very favorable for it. However, some things you can do that should be simple for you are setting the wheel alignment to zero toe and inflating the tires above stock pressure (many people here use between 40-50 PSI, just make sure you don't inflate it above max sidewall). After that, your biggest gains will probably come from aerodynamic mods. Of course, making the car lighter as well won't hurt, but it won't show as much of an improvement as improving the aerodynamic shape of the car.
