Thread: Oregon commuter
Old 05-12-2012, 09:15 AM   #83 (permalink)
Curtis in Texas
The fancy cable ends are silver soldered on, so why not see if you can remove the end you need from the old cable. If it comes off clean the try and install it on a new cable.
The square ends are nothing more than silver solder on the cable it'sself and then filed square.
Just go easy on the heat until you learn hot hot is enough to melt the silver solder. A (GOOD) Plumber should be able to knock it out with no problem.
Those kits usually have the tips you need, but if not just remove your old tip and transfer it over.
I've done a few in my time on custom cars and bikes I've built.
The Following User Says Thank You to Curtis in Texas For This Useful Post:
kozaz (05-28-2012)
