I was reading on another forum and saw this,
The injection pump is driven by a sprocket off the timing belt. There were many models of Bosch injection pumps; TDI pumps are all electronically controlled and most will work on 1996-2003 TDI (some need slight modification for fitment).
So if all of these pumps are electronically controlled, what ecu pinout is sending the signal to the pump? And can that signal be fed to mpguino?
