I failed to give a bit of information.
-I already posses the car and am set on using it. I will give it to you drmiller100, the 240z datsun is an gorgeous car.
-I am going with a LS engine since it has been done many times and is know to work well especially with the 944S transmission. Although I am going to have to figure out the gearing since the final gear is sitting at 3,000 rpm at 75 mph. Not the best cruising setup.
-I'm also doing this as a road racing car not a drag car. That might change a few things.
