Originally Posted by Weisheimer
Those parameters are set when doing the programming of the microcontroller for the first time before it is installed on the control board.
A Ponyprog is a device used to program the AVR microcontroller.
Did you buy a pre-programmed microcontroller from Paul, or was yours programmed by someone else?
Explorer works fine with a USB to serial adapter.
i would like to add that i'm pretty sure RTD explorer only works with a very few usb to serial adapters. i tried 3 of them (ones that look like a usb cable with a bulky serial connector on one end) and none of them worked at all. but adam (and me, but i can't remember the number on it) has one that works very well.
hope this helps
