Originally Posted by drmiller100
smaller cam and more boost.
That does make sense on the surface however the goal was great power and throttle response at large throttle openings, and very fuel efficient at small throttle openings. I must put a video together so you can hear how crisp this thing is ;-)
A small turbo produces a very small orifice for gas to pass through and therefore more back pressure. I chose a medium size turbo because it offers less pressure drop, easier smoother flow, and more cfm per lb of boost. I also plan to drop a new LS3 or maybe an LS7 in there later so wanted a system that will easily adapt over. Both LS3 and LS7 will get better mpg than my LS1 for the following reasons:
1 - LS1 is old - done over 100,000 miles
2 - A new LS3 or LS7 blueprinted and built right is very fuel efficient at part throttle - esp with some tricks to ensure very low leak down and friction reduction etc
3 - The LS3 or LS7 would go with a 6sp to get mpg up as the larger engines will see little (if any) mpg gain on an auto over what I have.
