Old 05-13-2012, 04:35 PM   #6 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Since my first touch pad mod prototype seems to be holding up, I decided to make the mod replicable.
Okay...here are some measurements:
Button spacing:
width = 1 15/16" x height = 1 5/16"
Minimum backing dimensions (w x h): 2 1/2" x 1 5/8"
Maximum backing dimensions (w x h): 3 5/8" x 2"
I went with a backing dimension of 3" x 2". I cut 2 pieces from some scrap Lexan. I'm using 2 pieces so the Tetrax Fix magnetic base will fit. I used a 1/2" hole to fit the magnetic base on my prototype.
Currently working on designing the backing plate to mountable on the factory windshield mount. The mounting plate will have enough space between it and the touchpad mod plate so the cleat will clear the back of the touchpad mod plate. I'll still be mounting mine to the dash instead of the windshield mount though.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
FXSTi (05-13-2012)
