Originally Posted by 2000mc
any ls engine with an aluminum block, 5.7 might be the easiest to find. whichever engine, if you use one out of a car you're more likely to be able to use more existing parts if you wanted to, thinking oil pan and intake for clearance. then just build for low end / torque.
- before you build, price out what gm has, standard engine in the corvette now is an all aluminum 6.2 making 430hp
you can get there with the old 5.7, but once you play with a 5.3 or a 6.0, you will NEVER look back......
