Old 05-13-2012, 08:32 PM   #28 (permalink)
Grant-53
Not to worry. A piece of wax paper will keep the goo off your tire and the pavement. Remember More's Law: If enough is good too much must be better. Actually a thin coat works fine. Most shops use a 1 ton hydraulic press to lay up sheets of laminate spaced with fiberboard.
