Old 05-13-2012, 09:04 PM   #11 (permalink)
Grant-53
The trick with an air cooled engine is getting air flow smoothly in and out of the fairing. A NACA inlet on either side of the dustbin ahead of the engine would work. The ideal exit point is near the rider's leg. If possible find a low pressure area behind the legs as the rear half of the fairing narrows. With the dustbin front you are looking at a long tail section to maintain aero stability. Consider an electric fan in front of the engine fins and a temperature gauge of some sort.
The Following User Says Thank You to Grant-53 For This Useful Post:
renault_megane_dci (05-14-2012)
