If you run an engine lean under load you will burn valves.
Even the lean burn civic only ran lean at light load.
Replacing exhaust valves every 10k miles isn't very economical.
That does not mean lean is bad, it just means lean is for light load.
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
