Originally Posted by Grant-53
Not to worry. A piece of wax paper will keep the goo off your tire and the pavement. Remember More's Law: If enough is good too much must be better. Actually a thin coat works fine. Most shops use a 1 ton hydraulic press to lay up sheets of laminate spaced with fiberboard.
So I guess my car does not qalify. It's 750kg altogether...
But I'll fix it, no worries.
