so the added angel joint where the carrier bearing is, will be the only thing that would make any difference.
its not a U-joint, its more like a ball on a pivot, and the small bearing in the carrier.
ok so not that much at all, just about more to be had by reducing 15ish lbs of auto load.
a bit of the cross member comes out to do it, plus the carrier bearing, granted the drive line will get a few pounds bigger...
clearly, much more to be had buy doing a gearing swap.
ill likely do bolth at the same time, being the auto will be getting many changes.
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED ![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif) NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
