Old 05-14-2012, 01:38 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Have you put it in the right mode , diesel A or B ?
There's an explanation of how to check that in the manual.
Then, you need to calibrate the Scangauge to the car - and your driving style to some degree - again, instructions on how to are in the manual.
When you correct the amount you filled up against what the SG thinks you used, correct it only half-way towards the right number to avoid overcorrection swinging the other direction.
