Old 05-14-2012, 08:38 PM   #1 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
CRX HF engine and 5 speed transmission
Also comes with ECM and an engine side wiring harness.
Unknown mileage, less than 200,000 for sure. (The guy wouldn't have pulled it if it were high.)
Engine and transmission are still mated with stock clutch.
Axles not included, but you use the axles of the car you're swapping into if it's a 1988-1991 DX, HF, or Si as long as its' already 5 speed. If it's a 1992-1995, you also use the stock axles, as long as it wasn't originally automatic.
Would take $500 for the pair, can deliver close to Johnson City, NY.
If separated, $300 engine and $300 transmission.
