Old 05-15-2012, 12:39 AM   #10 (permalink)
drmiller100
I want to tread lightly here,but according to boundary layer theory,once critical velocity is attained,and the boundary layer is turbulent,all structures will follow the 115-degree rule,regardless as to whether they're a plane,car,or submarine.
If air,or any 'fluid' is attacking a particular curve,of any given radius,if 'zero' is the forward stagnation point,the 'fluid' MUST separate at 115-degrees of rotation beyond the stagnation point.
Example: if an analog wristwatch is moving from right to left,and the air first strikes at the 9:00 position,the air will not be able to remain attached beyond 4-seconds after 12:00.By the way,the angle at the separation point is 22-degrees.
We must be talking about different things, and I would appreciate your patience in helping me understand what you are saying.
Where does Reynolds Number fit in with what you are saying?
Are you implying that all objects with all reynolds numbers all stall at about 22 degrees normal to the surface?
Surely that is not what you are saying????
