Old 05-15-2012, 02:08 AM   #11 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Originally Posted by drmiller100 View Post
airplanes operate at higher speeds then our cars - higher speeds imply different reynolds numbers which means they get to use different degrees of taper.
An example - airplane wings "stall" if you go too slow.
A stall can happen at any airspeed. It occurs when the wing reaches its critical angle of attack.
The taper in the example plane in the OP is very far from ideal and is an example of form following function. It will look like a mess in the wind tunnel.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
aerohead (05-15-2012)
