Old 05-15-2012, 09:43 PM   #15 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Here are the money shots, down on the suspension at a normal ride height.
I put the pan inside the arms of the A-frames themselves.
The edge of the plastic shows here, and especially where I could not get a screw in there because of the lift arms. I plan on using an aluminum carpet edge to clamp the plastic to the aluminum running board, with countersunk screws. I will paint the final edges with a rubberized undercoat.
The rear axle is in line or above the pan, except for the spring clamp bolts and shock mounts. I really did not want to squeeze the air. It starts out at ~10.5" ground clearance up front, maybe 10" under the crossmember, then tapers up to about 13" at the axle. I could lower the front section to match, but it would be effectively lower than the lowest front suspension component if I did. The crossmember is only about 25" wide in the low area.
It is down about 5" below the original bumper, but that will all get covered by the new bumper/spoiler. I ran with this much radiator cover over the pass the other day, and no fan.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 4 Users Say Thank You to skyking For This Useful Post:
BamZipPow (05-16-2012), darcane (05-16-2012), Diesel_Dave (05-25-2012), Sven7 (05-16-2012)
