Old 05-15-2012, 11:57 PM   #6 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Why not just swap the HF head on? It doesn't take long, and you get the proper intake manifold to deal with the required higher air velocity at lower speeds, as well as slightly larger valves than the 16V heads have, which allow better flow at low RPM.
And you can use the HF cam. You can also use your stock electronics to run that head, as long as you only use the head, and don't try to incorporate the recirc valve on the intake manifold.
I also have a complete HF swap I'm selling, if that's something you're interested in. It's currently in Johnson City at a buddy's house.
