Old 05-15-2012, 11:00 PM   #2 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
See if any version of your engine came without PS as an option in another car. Look how the belt is routed.
Generally, you can just use a smaller belt and still make contact with the idler and tensioner pulleys. If you can't, you may also be able to install a second tensioner, or use a dummy pulley in place of the PS pump by making a small bracket and bolting an idler pulley to it.
