The first gear is the same, the final changes it a bit. With the added low-end torque of the HF swap, you'd probably be net about the same.
One problem I had with the HF's gearing was that, even in my +100 HP sedan (~120HP at that time, IIRC), I couldn't pull anything except 3rd gear up long hills, and accelerating past 60 or so was just wishing in a bucket (on those hills). I was also running 205/40ZR16 street performance tires and hadn't done much else to the car at that point.
For the record, I'd entertain trades for the swap as well, if you know anyone that's interested in it.
