Old 05-16-2012, 02:36 AM   #16 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
*All structures which are moving at a velocity at,or above critical velocity are limited to the 22-degree slope angle in the aft-body.
I've measured the Shuttle tail cone on pics - it's also around 22°.
You can chop off the last 20% of a fuselage on an aircraft and it will never show on the fuel gauge.This is why the tails on the cargo planes matter very little to overall performance.
That's when starting with a fully streamlined fuselage.
On the Arava and Noratlas, the clamshell doors are at or very near the full fuselage width - not nearly the last 20% of the streamline.
On the C-82 it was a bit better, and best on the C-119 .
The operational drawbacks were many, and serious.
Not surprisingly, this WW2 design hasn't stood the test of time and was replaced with the rear loading ramp - pioneered on the Budd-ugly Conestoga (RB-1 / C-93) - which has become the preferred lay-out.
The Following User Says Thank You to euromodder For This Useful Post:
aerohead (05-16-2012)
