Originally Posted by Neen
Oh man that car definetly looks better on the outside than the inside...bummer. Anyhow, I love e fans! What was the rating on the stock alt? The fan will draw about 10 amps on start-up...you should be fine but you should double check the stock amp capacity. It's easier for a 80 amp alt to run at 40 amps than a 50 amp running at 40.
I am goimg to finish gutting the interior, so its ok for now.
From what I understand is these have weak alternators
the plan is to replace w a Gm 90-100 amp in place of the ac compresor in the future.
