Old 05-19-2012, 03:28 AM   #13 (permalink)
baldlobo
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
well most hub designs are double bearing leading to a decent life span for the bearings(two bearings really close would probably lead to one failing pretty quickly; think weight over distance); the hub centric design is so anyone can center the wheel(lowest common denominator); and it probably cuts down on the number of studs needed to carry the cars weight fully loaded(that and you can technically drive a good distance with only missing one lug nut from each of the tires)
