i think i'm looking at it wrong, but i think it looks like its from old 2wd vehicles, spindle, bearings, outer bearing races pressed into the rotor assembly, but they had wheel studs pressed through the rotor.
if you have the rotor attached to the wheel, how do you get the caliper off?
