Old 05-20-2012, 08:05 PM   #47 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by Christ View Post
This is probably the case with a large number of vehicles - however, that doesn't necessarily mean that the ECM is expecting the same range of temps from both. In fact, I can guarantee it's not.
That's exactly what I meant. The difference in what the ECU is expecting for each sensor.
Here's an air density vs. temperature chart that illustrates what Old Mechanic is saying above:
The difference in density between 70F and 160F is 15%. Can we assume that this difference will equate to a 15% difference in engine load, providing all other variables remain constant?
The Following User Says Thank You to mechman600 For This Useful Post:
t vago (05-20-2012)
