Thread: Scion XA in PA
Old 06-03-2008, 01:18 PM   #21 (permalink)
NeilBlanchard
Hello,
I could try the lower grill; but my guess is that it won't work as well -- but I should try it! The lower grill is recessed, whereas the upper one is flush. I also want to try covering the fog lights, though that will need a clear plastic cover.
Does your xA have a coolant gauge? Or are you using the ScanGaugeII? Mine just has a little light: it is blue when it is cool and warming up, it is off when it is normal, and it turns red when it is too hot. I have yet to see it red...
