Thread: Hello
Old 05-22-2012, 05:25 PM   #6 (permalink)
j8reign
80 miles is a pretty hefty range, but it is quite doable. I'm not sure for $10k though. 96V @ 200Ah gives you a 19 kWh pack. That is a fair amount smaller than the Leaf's 24 kWh pack that gives it its ~80 mile range. I'd try to pack a few more cells in if I were you. I'd also increase the voltage if possible as well especially if its going to get on an interstate.
Well, I won't be doing any interstate driving, but I will be driving the majority of it at about 55-60mph. So if I'm reading this right, I should shoot for the voltage/ah/kwh of a leaf? Also, I'm hoping that since the neon is fairly aerodynamic and since I've gotten the weight down so drastically that should help with range?
