Thread: civic issue
Old 05-23-2012, 03:10 AM   #10 (permalink)
mycivic
Originally Posted by drmiller100 View Post
just so we are on the same page, wiht a code 9, cyp, the engine does not start or run, correct?
could be the ecu is bad, could be the distributor is bad. the distributors all wire up the same on the ecu side, and there are only three styles from 88 to 2000 - obd0, obd1, obd2.
It actually starts and run fine, but just with a CEL and i dont think it goes into lean burn with the CEL on..Should it?
