It would seem most of the weight to be saved is in the brackets for the seats. A fellow neon owner made aluminum brackets for his factory seats and shaved off a bit of weight.
www.neons.org • View topic - 20lbs off stock seats for $35
I did a bit of research into lighter seats and found that even when you do get a light aftermarket seat, the brackets just bring the weight up.
