Old 05-24-2012, 04:24 PM   #4 (permalink)
BackroadBomber
Jenny - '02 Chevrolet Prizm Lsi
90 day: 31.45 mpg (US)
Crowley - '23 Ford Maverick XLT
90 day: 25.27 mpg (US)
Originally Posted by jeongyun View Post
I hope you adjust odometer reading when you calculate the MPG.
there's fairly large difference in circumferences between two sizes. about 4.5%
If you didn't you still got about 25mpg. Since your tires are about 4.3% off, next time you fill up multiply your mileage by .957 like this; because your new tires are 95.7% the diameter as your old set.
260miles/10gallons=26mpg. - wrong
260miles*.957=252.2. 252.2/10gallons=25.2mpg
Although, if the old tires on the truck aren't the original size, find the original size and google search a tire size calculator to find out the percentage they're off. I have to do the same thing with my ford ranger except backwards cuz I put taller tires on to bring the rpm's lower while cruising.
The Following User Says Thank You to BackroadBomber For This Useful Post:
brent777 (05-25-2012)
