getnpsi -
Originally Posted by getnpsi
I like this idea, but maybe with a different shape on the shift knob. If you look at this picture :
You can see that they are using a relay, but with only four pins. The 5-pin relays allow for normally closed momentary switching :
In the above, if you attach a "regular" momentary switch to connection 87, it will become a momentary open switch to create momentary fuel cutoff.
CarloSW2
