Old 05-25-2012, 10:05 PM   #51 (permalink)
OneOfFew
Civic HX - '96 Honda Civic HX
90 day: 40.05 mpg (US)
Originally Posted by California98Civic View Post
Here is the wiring diagram for the charging system, taken from the Honda Service Manual for the 1996-1998 Civics. You'll see that the large gauge white wire running from the alt to the battery also has a connection back to the regulator, seemingly still inside the alternator. I think that's the culprit, here. What do you think?
I think I have proven your hypothesis true. I created a circuit that disconnects all 4 wires on the connector and is STILL generates power. The voltage is unstable but it creates power, up to 25 amps of power at 12-13v. I used a ~70amp load tester with the alternator circuit disconnected after engine start. I was very surprised. That connection to power internal to the alternator is keeping the regulator running, as you thought.
I'll post some details in a few.
