Old 05-26-2012, 11:17 AM   #8 (permalink)
brent777
master modder
brent777's Avatar
ticker - '97 nissan d21 xe
Pickups
90 day: 27.06 mpg (US)
Send a message via Yahoo to brent777
Originally Posted by mwebb View Post
all systems run most of the time at an
Air to Fuel ratio of 14.64 to 1
1 part fuel
14.64 parts air
by weight
so
1 part of fuel will have much less influence on the temperature of the complete mass entering the combustion chamber than the 14.64 parts of air
and
on systems that have a return line
that extra unused very heated fuel goes back to the fuel tank , heating the fuel in the tank
which causes heavy duty evaporation and pressure build up in the fuel tank much of that pressure and HC
can
be vented
to atmosphere
because most systems are not designed to handle that scenario
fuel vented to atmosphere does not increase FE as it is
wasted
10% improvement .... not very likely
your right!!!!!!!!! but what if we bypass the return line?
-its hard to have a fun life if you don't have fun in life-
