Thread: field repairs
Old 05-29-2012, 03:44 PM   #1 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
field repairs
Had a bit of drama in the mountains Friday. I hit an unexpected huge rut in the road while towing the 10,000 pound travel trailer. truck bottomed out like never before, and a projecting part cut the right rear hard brake line and started dumping fluid. I was going down a 5% winding grade and started losing pedal fast. I applied trailer brakes, limped on down into a little town where nobody had brake fluid or tools.
I unhooked the trailer, finished cutting through the line with a pair of pliers, and folded it over and hammered it shut with a hatchet. Leak stopped, 3 out of 4 truck brakes restored. I scooped fluid from the reservoir that had plenty to the one that was low, pumped them up and had a good pedal. hooked the trailer up and got it to the campground. Saturday I took the truck to a nearby NAPA that had a generic line and the wrench I needed. Bent up new line, added fluid, bled the brakes out in the street. Bedded line with zip ties and silicone.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
BamZipPow (05-29-2012)
