Old 05-29-2012, 07:12 PM   #269 (permalink)
hoover
Z - '04 chevrolet silverado 1500 Z-71
smooth wheel discs
My truck is a 2004 silverado with 16" factory aluminum rims. I used 1/8" abs plastic for my wheel discs. Took the factory center hub cap off and drilled a hole in the center of it. Then I filed the hole square, and pushed in a license plate plastic insert into the square hole. Used a license plate bolt to hold it. The steel bolt into the plastic does not seem to ever come loose. Just one more possible solution to this problem.
