Old 05-29-2012, 07:31 PM   #5755 (permalink)
electricstorm
Thanks everyone for the response.
I was mainly concerned with having to replace the Cincon should it happen to fail. But it sounds like no one has had a failure so I guess I'll go ahead and solder it in.
One other question. Can the control board be tested without the power board as far as using a scope and checking signals? Or is it best to have the whole unit assembled before testing?
Planning on doing some checking of the circuit and then completing the power board, assembling and testing with an old starter as a first load test.
Jim
