Originally Posted by trikkonceptz
...I know it sounds crazy, but I guess Ill try it till the tranny blows, then at least I change over to the 6 speed manual...
Yah, if a manual swap is doable for you, don't show any love for that auto
In fact, you should hook up a control circuit so you can select a gear and lockup the converter and see how many times you can bumpstart it
