Old 05-30-2012, 10:29 PM   #16 (permalink)
drmiller100
If I were doing your trailer,I'd use the height as the layout parameter,since the trailer is wider than it is tall..
but there is only one top, and two sides.
And the advantages on the bottom are TOUGH to not screw up.
Again, I'm not very sure on this, and am TOTALLY willing to discuss it.
I think you do 1:3 on the top and sides, and radius about a foot at the transition from the tail to the trailer.
Be CAREFUL during that foot - don't do anything to create separation, but don't worry about the 4 corners around your tail- if you screw up the corners, you create a vortex which helps fix any separation.
