Old 05-31-2012, 12:13 AM   #14 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Sounds similar to what I did with my truck. I used a Four Seasons 74777, though.
All of the heater valves I've come across will allow some seepage past the valve itself. I suspect this is intentional, so as force all of the coolant to stay at a uniform mixture. For bypassing the heater core, the seepage isn't enough to really affect discharge air temperatures coming out of the HVAC housing.
However, for fully shutting off coolant flow, such as with my HAI setup, these valves are not quite adequate.
The Following User Says Thank You to t vago For This Useful Post:
brent777 (06-06-2012)
