i have an automatic transmission, so im not too interested in the idea and haven't read any threads on the idea. i assume all you would need is a push switch(like a push button start), a relay and some wire. most cars keep a constant voltage to the injectors and modulate the ground, use the button to control a relay that would eliminate a ground for the injectors. as soon as the engine dies, let off the button.
