Old 05-31-2012, 07:19 PM   #6 (permalink)
oil pan 4
A 6.2L or 6.5L chevy diesel will bolt right up to your frame and would likely work with what ever transmission you have in there, if not a transmission would be very easy to find and be fairly cheap.
You can get a BT4, but how economical is a $4000 engine that will require a lot of fabrication work to get it to fit. And good luck finding a transmission (and you will need a custom length drive shaft too)
If I can get mid 20s with a 6.2L in my suburban than a 57 should get closer to 30.
