Old 06-01-2012, 02:29 AM   #8 (permalink)
oil pan 4
Absolutly under no circumstances use an electronicly controled DB4 serries injector pump.
The after market has been working on fixing the Pump Mounted Driver for over 20 years now and still cant get it right.
I have had 0 problems with my injector pump in 6 years and I have abused it in ways that make DB4 guys cringe, mainly because I do things like put used motor oil in my fuel on a regular basis. That would instantly put a DB4 pump into limp mode, due to blinding the optical sensor set up they use.
