Hello!
I just installed the MPGuino on my VW Golf -94 1.8l 66kW Mono-Motronic system. One-point injector.
I found the VSS signal.
And i found the injector plug, 4 pole. 1 has voltage, and 2,3,4 has 0V.
So i picked the rightmost pole, where is 0V, but it does'nt bring anything to MPGuino.
Should all the three poles give reading or just one?
And does anyone know about this car?
And another thing, how soon it is supposed to give litre readings when you start using it? Immediately? Even though the starting values are garbage?
Thanks
