Old 06-03-2008, 08:06 PM   #111 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by fritz View Post
for gear ratios this might help. also looks like swapping 5th gears is easy
http://hondaswap.com/civic-crx-ew/hf...-tranny-70579/
yeah according this this post you can do it in the car.. HMMM may have to investigate that and see if i can find the new gears..
"for the 84-87 trany's...to get the 5th gear.....you don't have to swap the trannies. You don't even need to remove the tranny. Just pop the tip cap nearest to the passengers wheel, and the 5th gear is located right there...pop the gear out of the SI tranny, put the HF gear in, button it up, call it done....some oil might be spilt out, but not enough to even worry about adding more oil."
