I went with black for a few reasons--black was readily available, whereas factory matching color would have had to be ordered, and I thought it might look weird with the negative space of the stock grill and foglight hole covers turned red. I wasn't planning on extending the black that far out the sides, but I got carried away sanding.
Plus, the black will match my eventual tail.
Originally Posted by Varn
Nice job Vman. How do you see out your side mirrors. Seems like there may be some safety issues. When I had an Illinois drivers license I was required to have outside mirrors. It is a fairly common restriction.
Do you have narrow mirrors in your flattish panels?
Nope, just some interior convex mirrors from Autozone. I can see just as well as with the stock mirrors, and Illinois only requires one mirror(!), "so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such motor vehicle." So, blocking the rear window would make the interior mirrors no-go, but as it sits it's legal (but not in Washington, where it's registered until the tabs expire later this year).
