Old 06-02-2012, 12:41 PM   #36 (permalink)
TX_Dj
TX_Dj's Avatar
Mega - '07 Dodge Ram 3500 4x4 Mega Cab Dually SLT
Last 3: 20.68 mpg (US)
Akane - '11 Honda CBR250R
Motorcycle
90 day: 51.66 mpg (US)
As long as the throttle isn't stuck such that you're pegging the redline without a load, keep in mind you can use your friction zone to regulate your speed... and of course the killswitch to shut 'er down when needed.
If you're getting that much water in there, I'll bet rust is contributing factor inside the cable housing. May be a good idea to buy/build new cables, and really thoroughly fill them with heavy grease with some manner of injection method.
Are you sure it was actually the cables causing the problem, and not water inside the throttle mechanism itself, or water/ice around the cam on the carb-end of the cable?
2007 3500 MC DRW 4x4 5.9L (120k mi)
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 19.78 city
2011 Honda CBR250R (brand spankin' new)
