Originally Posted by RiderofBikes
OH, and......... For all you Fiesta owners, learn from me..  do not mix diesel/gas at any rate. the computer wont like you, and it leaves a bad bad residue out the pipe... Dummy Light popped on after 3days (about 1:7 ratio) gonna run this through first and pull the O2 censors out and clean them by next week if it doesnt clear up on its own(hopefully).
Don't run the tank empty on this mix to get rid of it ASAP.
Top it up as often as you can and dilute the diesel as much as possible if you don't want to drain the tank.
