Old 06-04-2012, 03:33 PM   #67 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
I didn't look back at your aero setup but obviously you don't want to create lift on the back.
Lift on the back is gonna lift your front wheel.
The (maybe) 4 pounds of your bike battery is not gonna do much.
Maybe you can try to sit further front ?
Those bikes (SR or GN) have a custom style geometry with a rather short wheel to wheel distance making them not very stable to start with, even more so if one drop the fork in the clamp making it a little shorter and a little less stable.
I am planning on swapping my rear swing arm for a longer one just to cure this issue.
Check out my build thread, there is a picture of the bike with a longer swing arm (not too easy to fit thought)
